Author Topic: Mk1 GTI 1600 starting problem NEED HELP!  (Read 6244 times)
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« on: 07 September 2007, 13:40 »
I went into town last night (which is a walk away so wasnt to hard getting home) and the engine died it died as i put the clutch in (engine was idling) reved it then as it dropped it died, failed to start if left for a min then try again it fires for a split second then dies again and still nothing. i have noticed when i do this sometimes my rev counter needle go a bit nuts. It has done this whole thing before and i left the car for a few hours and came back and it started. I did the same when i came back to the car 7 hours later so it was proper cold start. Turned it over still nothing, i have changed the plugs at this stage (it has new coil & HT's as i changed these a week ago. after plug change still nothing. Got some brandex easy start took the inlet hose of the air box sprayed a bit and hey it ran for a second again.
The engine is a k-jet
So i have come to a point that its firing and burning the brandex so there must not be any fuel entering.
I read through the handy haynes manual and it metions the cold start valve which is the 5th injector bolted to the side of the inlet manifold a cracked the banjo bolt open a little and petrol pis*ed out, did the same on the banjo for the fuel in after the fuel filter to the metering head and spss petrol is compressed for feed.
In the hynes it says the cold start valve is ran by the thermotime switch which is on the outlet (return) water pipe.
Do you think it is this that is not working correctly either the cold start valve or thermotime switch?
I did pull one of the injectors out and turned it over and nothing came out, i reffered to the haynes and it says these only spray if the engine is warm/hot started. It also mentions to check the fuel pump relay, but i have put my hand on the fuel pump when turning over and it is feeding (i can feel it pulsing).
Please please help  i start my new job monday and need her going again maybe someone else has had a similar issue.
R98 HUF
Re: Mk1 GTI 1600 starting problem NEED HELP!
« Reply #1 on: 07 September 2007, 13:41 »
Time to get that new engine fitted mate!!!!!
You only have 2 1/2  weeks for Brands!
Offline G60GTI16V
« Reply #2 on: 07 September 2007, 13:43 »
i know just starting a new job monday so engine change day has been changed tilll...  i dont know  :shocked:
R98 HUF
« Reply #3 on: 07 September 2007, 13:46 »
Hope you get it running for monday then!!!!!
Ill be at Brands but may not have the MK3, considering a MK2 16v 3 door!!!!
« Reply #4 on: 07 September 2007, 13:46 »
dappy rev counter is a symptom of a dying hall sender in the dizzy, check the wires havent snapped there!
Offline mk1GiT
« Reply #5 on: 07 September 2007, 14:16 »
if your getting no fuel to 1 of the 4 injectors and the pump is running, maybe the fuel filter is blocked ?
1600 GTi daily driver
Offline G60GTI16V
« Reply #6 on: 07 September 2007, 14:19 »
but the haynes manual states that if its cold start the only injector that sprays is the cold start valve bolted to the side of the inlet manifold... oh and i have cracked open the banjo after the filter and theres loads of pressured fuel there.
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #7 on: 07 September 2007, 14:20 »
I was thinking ignition amplifier/TCI switch - which is where those wires go  :smiley:
I've got a spare dizzy with loom & amp if you want to try any of them
 :undecided:  Actually, with you're fuel pump problems as well it could very well be a wet fusebox, did it start playing up after it rained? (mine has  :sad:)
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline G60GTI16V
« Reply #8 on: 07 September 2007, 14:27 »
is the amplifier the vacuum amp or the switch unit for ignition?
dan
ps the fuel pump issue is not mine my friend is after one thats all.
fuse box is dry man.
« Reply #9 on: 07 September 2007, 14:42 »
mk1mad is on about the thing bolted to a bracket in the rain tray area :)
