Author Topic: Air con always on?  (Read 3221 times)
Offline speedynz
Air con always on?
« on: 31 August 2007, 21:50 »
I am about to take delivery of an Edition 30 GTI and from the owners manual it looks like the A/C is always running if you have the fan turned on, is this true or can you run the fan with no A/C???
EDITION 30.
I couldn't eat a whole one.
Offline Cass
Re: Air con always on?
« Reply #1 on: 31 August 2007, 23:46 »
I'm sure aircon compressor is switched off in ECON mode.
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline speedynz
« Reply #2 on: 31 August 2007, 23:47 »
Cass
Do you mean always off, or switching on and off as required?
EDITION 30.
Offline Teutonic_Tamer
« Reply #3 on: 01 September 2007, 10:21 »
Just to throw a spanner in the works, from model year 2008 (ie cars now available) the air con switch has been changed from "ECON" to "A/C" - makes sense (why they never had it like that from the start beats me!)
Anyhow, as Cass correctly stated, pressing the ECON switch, so that the LED is illuminated will manually switch off the air con.  However, this IS over-ridden if you press either the "recirc" or the mega-blast windscreen defrost (the semi-circular switch inside the left temperature switch, and not the rectangular distribution switch).  When you subsequently cancel either of these selections, the air con will continue to run, so you will need to manually press the econ again.
If you use the "AUTO" function, then the aircon will run continuously.
There is no WOT aircon temporary disable, but there is an external temperature disable (below 5degC, I think!)
I feel like a homo
Offline speedynz
« Reply #4 on: 01 September 2007, 10:26 »
Thanks TT, very helpful.
EDITION 30.
« Reply #5 on: 02 September 2007, 08:34 »
You're welcome.  :smiley:
Just to clarify a small point, between the different model-year switches.  With the "ECON" switch, pressing it so that the LED is illuminated turns the aircon OFF.  With the newer "A/C" switch, pressing it so the LED is lit means the aircon is ON.
I feel like a homo
Offline speedynz
« Reply #6 on: 02 September 2007, 09:34 »
Got ya. :smiley:
EDITION 30.
Offline NORTHERNER
« Reply #7 on: 02 September 2007, 17:41 »
As an aside, whilst I am running my engine in I am avoiding putting the aircon on as I believe it puts a strain (albeit small) on the engine.. am I nuts, or is there any logic in me doing this?  Currently following the progressive max RPM approach that TT advised... only another 100 miles to go and I can move up to max 4500...  :smiley:
Mk 5 GTi, Tornado Red, Leather, Xenons, 18" Monza II's, Sunroof, 6CD in Armrest, Winter pack & Tinted Windows... soon to be adding ED30 front spoiler, plus R32 sideskirts... then getting fully colour coded!
New engine fitted when car was at 27k... last one went "noisey".
Offline Rhyso
« Reply #8 on: 02 September 2007, 18:11 »
should run your aircon for at least 10 minutes a week as i believe it helps keep certain parts of the system lubricated and thereofre prevent cracking.  Not sure where i've picked that up so i could be wrong lol
Offline speedynz
« Reply #9 on: 02 September 2007, 20:44 »
^^^^You're right Rhyso^^^^^
Northener I am a little aircon fickle too, it doesn't strain the engine but it will use a small amount of it's power and mildly increase fuel consumption.
EDITION 30.
