Author Topic: number plate recess  (Read 1214 times)
Offline weazgti
number plate recess
« on: 31 August 2007, 13:44 »
where do these people get there number plate recess s from when they fit a smooth boot?
Offline dabill
Re: number plate recess
« Reply #1 on: 31 August 2007, 14:08 »
dont fully understand what you mean, are you on about, how do people smoothe the tailagte and what do they use to fill in the recess?
if so, then usually they spot weld a plate which si cut to size, then run a seam weld all the way around it, then grind and smoothe flat, fill and paint.
rob
noble tuned - and still not fast enough!
Offline golf8v
« Reply #2 on: 31 August 2007, 17:53 »
