Author Topic: Main bean "warning" light  (Read 1427 times)
Offline pork_pie
« on: 31 August 2007, 04:57 »
hi all
has anyone ever replaced the blue LED that tells you your main beams are on?  i know its gonna be a dash out job *sigh* but i need to know if i need to de-solder it from a PCB, or if it just plugs in.  also, can anyone tell me where i can get one?  apparently if this light doesnt work, its an MOT failure  :angry:
cheers
Mk2 16v is off the road :(  Mk3 8v has taken its place :)
Offline Mew
Re: Main bean "warning" light
« Reply #1 on: 31 August 2007, 11:28 »
Mine doesn't work and it passed an MOT. It just got put as an advisory, but the guy said it would never be a fail.
Offline pork_pie
« Reply #2 on: 31 August 2007, 17:38 »
aye, i think the guy was just an ass to be honest.
but, i would still like to fix it, makes life a little easyer...
cheers Mew
Offline andydavey
« Reply #3 on: 01 September 2007, 18:52 »
Are you sure it's the LED that's failed? They rarely do when not exposed to voltages outside their rated range, I'd look elsewhere for the problem personally.
Offline herbster
« Reply #4 on: 01 September 2007, 20:45 »
 :smiley:
they do blow, had to do this job on my passat years ago, they are pennies from the dealers and just push in the mounts, good luck, the dash isn't that bad just take your time and it will be good.
FAB is my life and the CABRIO's the wifes!!!!
Offline pork_pie
« Reply #5 on: 02 September 2007, 00:31 »
its not compleatly gone tbh, its just really dim.  didnt make that clear, soz.  would this point to another problem?  a high resistance somewhere?  or maybe the LED is fitted back to front?
glad to hear its not a soldering job.
thanks for the comments
Offline andydavey
« Reply #6 on: 02 September 2007, 23:20 »
Mine's pretty dim as well actually, never bothered me though I have to say. If it was in the wrong way round it wouldn't work at all, also they don't half blow as it were, they either work or they don't so changing the LED won't fix the problem in your case.
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #7 on: 03 September 2007, 17:41 »
being an electronic engineer i have to agree with the above post, if its dim changing it wont necessarily solve the problem.. bad earths contribute to dim leds..
anyways y the worry bout soldering, its a doddle  :tongue:
Offline pork_pie
« Reply #8 on: 04 September 2007, 15:48 »
righto, i will get the diagrams out, and look for a bad earth.
i know its a doddle, i just hate soldering LOL
