Author Topic: fuel leak help please - now with pic  (Read 831 times)
Offline monkeyalan
« on: 27 August 2007, 18:14 »
I've discovered a slight fuel leak from around the fuel accumulator/reservoir area but i'm not sure where yet.
If it turns out to just be a loose line or perished hose do i need to do anything to stop fuel spurting out if i undo anything or will it just be a trickle that needs catching?
cheers.
« Last Edit: 28 August 2007, 16:05 by monkeyalan »
Offline DarnPB
  • Formerly Darnpistonbroke
Re: fuel leak
« Reply #1 on: 27 August 2007, 18:34 »
You may get an initial spurt, but it will reduce to nothing unless the pipe end is lower than the tank itself. Disconnect the battery before breaking into fuel systems.
