Author Topic: Water/oil temp after water pump and thermostat change.  (Read 861 times)
Offline 8vRicey
  • Silver Mettalic 8v GTI
Changed the water pump this weekend and at the same time fitted a new themostat and removed the bypass-valve for the copper tubing mod. Have used 3litres of the G11 type coolant (roughly 50% of total coolant capacity), and am pretty sure i have refilled without any air-locks.
Prior to this water temp used to sit on the 1/4 marker rising to 1/2 in traffic, and oil temp was usually about 100-106
Water temp is now on 1/2 way marker with little movement in traffic, and oil is about 106-112.
Any cause for concern ??  :huh:
Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
Offline Mew
Re: Water/oil temp after water pump and thermostat change.
« Reply #1 on: 27 August 2007, 18:26 »
Every golf that i have had sits at around half way on the temp gauge pretty much 100% of the time. Oil once warmed up can be anything upto 106, but normally around 96.
They've all been on 8v's.
Offline Simpson
  • one day il learn
« Reply #2 on: 27 August 2007, 20:11 »
i concur if your thermostat was fecked prior that would explain it sitting halfway now  :smiley:
i must buy a new car!
