Author Topic: Bluefin and Exhaust  (Read 1374 times)
Offline Hilton_K
Bluefin and Exhaust
« on: 25 August 2007, 13:44 »
Hello,
I have an 07 MK5 GTI with Superchips Bluefin installed 244HP at the fly :smiley: I am thinking about installing a new dump pipe to the stock cat back system. From the research I have done seems as though the stock cat back is VERY good but the dump pipe and cats can be improved.
Still deciding/researching on the size to go for, either Miltek's 2.75", AWE's 2.5" or APR's 3" dump pipe
Question is,
Will I need to get a new map from Superchip to accomodate for the new system or is there enough in the program for it to get the full advatages out of the new less restrictive dump pipe?
Cheers,
Mitch.
Offline Hilton_K
Re: Bluefin and Exhaust
« Reply #1 on: 26 August 2007, 12:18 »
So nobody had any experience with adding an exhaust while Bluefin'd  :sad:
Offline Hurdy
« Reply #2 on: 26 August 2007, 14:11 »
I had a Milltek and Superchip, but only on my last car which was a GTTDI. I had them fitted at the same time and although you can optimise the milltek through a custom tune, the Superchips method is usually a stock remap with a slight tweek to it. I guess it will enable you to make a small gain if you do optimise, but I doubt that there would be much in it.
Seat Leon Cupra Black 290 DSG
Offline Hilton_K
« Reply #3 on: 27 August 2007, 10:37 »
Thatnks for the info
