Golf mk2
Lights
Topic: Lights (Read 1025 times)
helios
Lights
24 August 2007, 18:55 »
A small question.When I press on the light switch once should I get both lights on or does the drivers side light only come on ie like a parking light.I have full beams and normal lights.The only reason is that it is law to have your lights on in bad conditions over here in Ireland.When I had the Corrado which had the same light switch as my new golf when I pressed it down once I had both lights.Just wondering?
golf8v
GTI forum regular
Re: Lights
24 August 2007, 18:58 »
yes you should have both side lights!! if you take keys out and leave lights off .if you put indicator on this will control parking lights
stomper
Re: Lights
24 August 2007, 21:46 »
If your ignitions on both side lights should be on when you press the light switch once.
Press it two stages and your dipped headlights should be on.
If the ignitions off your on parking light control by the indicators.
2003 Black Magic Bora Sport 1.8T (180)
AMD remap
Milltek Cat-back exhaust
18" BBS RC's
Eibach 30mm Springs with Boge Shocks
Front and Rear V6 4Motion Valances
DarnPB
Formerly Darnpistonbroke
Re: Lights
24 August 2007, 22:17 »
Sounds like you have a side light bulb blown.
helios
Re: Lights
24 August 2007, 22:21 »
Think I have a bulb and all at home,hope thats all it is.I presume its easy enough to fit??havnt changed a bulb on a mk2 yet.
helios
Re: Lights
30 August 2007, 22:31 »
Blown bulb- sorted.
Golf mk2
Lights
