Author Topic: Fuel blockage?  (Read 671 times)
Offline firstVW
Fuel blockage?
« on: 24 August 2007, 15:34 »
Hello dubbers,
I recently returned from 6 months travelling and was so happy to be bk with my golf. It needed a lot of work as i hit a stag, i live 2 miles from stonor park, just before leaving and had no time or money to do anything about it. I got it all fixed and running and took it for an mot, which after a good dose of carb cleaner, passed the emissions test and the mot. Last night after stopping for about 10 mins, my car started running like a knackered 1 litre corsa. It sounds like a light aircraft, smells strongly of fuel and the revs go up in small chunks. My car is a 1.6 driver, 89 model with webber carbs. Any suggestions on a solution or just theories would be much appreciated.
Thanks all
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Fuel blockage?
« Reply #1 on: 24 August 2007, 18:43 »
possibly the rubber gasket block thing underneath the carb, its like a flange, that perishes, has it go on mine causing all sorts of funny air leakages, also check all the vac pipes gonig to and from the carby  :smiley: not as many as a pb, ut, theyll still be there
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline firstVW
Re: Fuel blockage?
« Reply #2 on: 25 August 2007, 13:23 »
Cheers matt. Had a look at that flange thing under the carb and it needs replacing. Where did you get your replacement from?
