Author Topic: Ecotek CB26 Valve  (Read 3613 times)
stripe
Ecotek CB26 Valve
« on: 20 January 2003, 10:17 »
Just fitting an ecotek valve to mu MK4 1.8T
SHould improve fuel economy and performance.
I will post my findings here soon..... :)
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Omar
Re: Ecotek CB26 Valve
« Reply #1 on: 28 January 2003, 12:05 »
I've been looking at the press hype of the Ecotek device. Have you had any joy with it then, or is it a gimmick??   :)
stripe
« Reply #2 on: 29 January 2003, 10:20 »
It's a little to early to tell yet, but I will post my findings in the next month.
It takes a while for the computer to adjust to it as it was reading 168 MPG for around 20 miles!!!!
stripe
« Reply #3 on: 05 March 2003, 10:23 »
Hmmm...
Not that impressed at the moment! Computer in the car said I was getting around 28-29 mpg, when I filled up and checked it at was only doing around 25 mpg!
I need to check the mechanics of the device and make sure I set it up correctly.  I consider myself Technical so it might just be 'bedding in'.
Omar
« Reply #4 on: 05 March 2003, 12:12 »
hmmm indeed.
So its not a miracle device then, keep us posted anyways.
Thank you   :)
stripe
« Reply #5 on: 26 March 2003, 09:10 »
Still NOT Impressed!!
25MPG Again!
I've adjusted it again and I'll give it one last try but I don't think it will do any good, I'd Like to try it on my 520i (Normally aspirated) but I can't fit it anywhere.
Keep you eye on this spot for the next update!!
Offline Bigdunc
« Reply #6 on: 20 February 2012, 22:05 »
I had one one my mk2 gti and it improved mpg but tbh i dont think it would work on my 1.8t as the fuel mixture is all done by the ecu and sensors
Offline Toby
  • Car - less
« Reply #7 on: 20 February 2012, 22:13 »
U found this 9 years on  :huh: :grin:
Currently down under
Offline MrRogers
« Reply #8 on: 20 February 2012, 23:12 »
Lol this is funny its weird looking back at the very 1st posts on this forum if you start from page 1 lol
2000 Golf MK4 1.8 AGU black magic, Custom Code stage 1 remap, Forge 008, Simota Aeroform CAI, G60/VR6 Combo, Weitec GT Hicon coilovers, Golf GTI MK5 18" Monza style alloys, 10mm H&R spacers front + 20mm H&R spacers rear, OEM Polo MK5 aerial, Whiteline front ARB + Whiteline droplinks.
Offline shaft69
« Reply #9 on: 20 February 2012, 23:20 »
Is that one of those thing that fit in vac line???
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
