Author Topic: Struggling to get car in 1st gear - PICS ADDED  (Read 1153 times)
Offline T_J_G
« on: 23 August 2007, 17:07 »
I think i've identified the problem, there a rod poking up to which my short shifter attaches onto. I think there is a rubber missing. Am i correct? There seems to be alot of play in it when i think it should be pretty tight. Nte only have problems with 1st.
Got a pic if needed?
Thanks
Tim
« Last Edit: 25 August 2007, 16:13 by T_J_G »
Offline T_J_G
Re: Struggling to get car in 1st gear
« Reply #1 on: 23 August 2007, 17:21 »
1.8 Digi 8v 1991
Offline bomp
« Reply #2 on: 24 August 2007, 00:43 »
Yeah, I get a bit of a crunch when changing down from 2nd to 1st. But it's ok if I just change down slowly.
I changed the long & short selector rods hoping that it would be cured, but no luck. And bought a relay shaft bush off mk2mark just to take up the sloppy movement out the gear change, (it dont crunch as bad with his bush in now though) but I think I'll have a go at the shift lever adjustment next, as per here http://www.iol.ie/~kilkennyhockey//BentleyManual/TM01/ch4.1.1.html Fig.4-5, but I need to get a feeler guage first to get the distance right.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline T_J_G
« Reply #3 on: 24 August 2007, 14:50 »
anymore ideas for this. I need to get the rubber sorted if there is one. It's a pain pulling away!
Can get some decent pics if you want.
Offline T_J_G
« Reply #4 on: 25 August 2007, 16:13 »
anyone help?
Offline Philpy
Re: Struggling to get car in 1st gear - PICS ADDED
« Reply #5 on: 25 August 2007, 17:00 »
Im sure my 16v has got a rubber there mate...  :sad:
Offline T_J_G
« Reply #6 on: 25 August 2007, 17:02 »
hmm i need to kow for a def and what it's called/part number.
It's a pain to drive
Thanks for you help though  :smiley:
Offline Ben Lessani
« Reply #7 on: 25 August 2007, 19:10 »
Its not rubber - its a poly bush. I've got a couple spare, PM me your address and I'll post one to you ;)
Offline bomp
« Reply #8 on: 25 August 2007, 23:35 »
You need two, one at the top and one at the bottom.  Rubjonny made a great howto here http://www.golfgtiforum.co.uk/index.php?topic=33100.0
The bushes are the 2 clear type and slightly larger than the others in the pic. I think the VAG ones are prolly better than the GSF ones though. (Firmer and better quality)
