Author Topic: Mk2 16v, which suspension?  (Read 1622 times)
Offline stomper
« on: 23 August 2007, 11:32 »
I've decided to get some suspension on my valver, not too much of a drop and don't want coilovers.
Thinking about Boge turbo's with eibach 20 or 40mm springs and new top mounts.
I've heard a few people recommending H&R springs over eibachs.
Are Boge turbo's a good shock or is there an alternative.
Looking to spend no more than £300 for the parts really.
Any comments would be appreciated.
Stomper
2003 Black Magic Bora Sport 1.8T (180)
AMD remap
Milltek Cat-back exhaust
18" BBS RC's
Eibach 30mm Springs with Boge Shocks
Front and Rear V6 4Motion Valances
Offline Organisys
  • Old and Slow...
Re: Mk2 16v, which suspension?
« Reply #1 on: 23 August 2007, 12:28 »
Have heard H&R are good, but no direct experience.
For you budget I think Boge Gas is your best bet.
« Last Edit: 23 August 2007, 12:50 by Organisys »
VeeDubGTI16v
« Reply #2 on: 23 August 2007, 12:33 »
see if you can get some 2nd hand koni top adjustable shocks + eibach springs, they are the next best thing to coilovers imo!
Offline stomper
« Reply #3 on: 23 August 2007, 12:37 »
Have hearn H&R are good, but no direct experience.
Cheers mate,
What's the difference between boge gas and turbo's, which are better?
AMD remap
18" BBS RC's
Offline Organisys
  • Old and Slow...
« Reply #4 on: 23 August 2007, 12:55 »
Same thing, as far as I know.
http://www.vwspares.co.uk/g2suspension.php
"Sealed Unit, Gas 115159 £29.80 ea "
 :smiley:
Offline stomper
« Reply #5 on: 23 August 2007, 13:02 »
Ok cool, was probably going to get them from GSF but makes no difference really.
Is it worth getting G60 top mounts over standard ones, same price.
Seen a few people use them lately.
Might give the H&R springs a go, a mate of mine had them on his mk2 and said they were good quality and decent ride.
Anything else i need to replace while i'm at it?
AMD remap
18" BBS RC's
Offline Simon8v91
« Reply #6 on: 23 August 2007, 13:19 »
 :smiley:
Just put those sachs gas on mine.  Really pleased with them.  They come with a new top nut but not new strut to hub carrier nuts.  The rear shocks for the 8v come with top nut, washer for top of bump stop and new circlips.  I would presume the 16v is the same.
I went for standard VW springs but if I had lowered I would have gone with eibach  :smiley:
Offline Organisys
  • Old and Slow...
« Reply #7 on: 23 August 2007, 13:21 »
G60 top mounts are allegedy stronger.
While you are there, check the condition of the bump stops and the strut sleeve/cover.
When you have finished, wait a week, then get the alignment setup.
Offline monkeyalan
« Reply #8 on: 23 August 2007, 13:42 »
sorry to hijack but while were talking top mounts, is a sign that they're knackered a sort of rubbery groaning noise when turning the steering wheel?
I've lubed all the joints in the steering column but it still does it when the cars warmed up which leads me to think its engine bay related.
Offline Simon8v91
« Reply #9 on: 23 August 2007, 13:50 »
Top mounts tend to have play in them when knackered.  Give each wheel a good shake and see what you can discover.  My guess would be ball joint(s) somewhere  :smiley:
