Author Topic: Carb cleaner to sort that idle for good!  (Read 1591 times)
Offline samco-jack
« on: 24 February 2004, 18:28 »
Hello Buddies ,I brought some spray carb and injecter cleaner today to spray the ISV .And was thinking about taking out the spark plugs and giving a good spray into the head.Is this a good or bad idea?Where else can you give a good spraying with carb cleaner?
turbo
Re:Carb cleaner to sort that idle for good!
« Reply #1 on: 25 February 2004, 00:10 »
throttle plates, breather pipes,...
the best way to clean the inlet valves and throttle is to spray it into the breather pipe which runs from the top of the rocker cover to the front of the throttle with the engine running.......if you pull the pipe off it will stall to get around this problem undo the jubelee clip slide the rubber pipe off (this is where is connects to the daft big black bit on top of rocker cover) and slide the straw in and then slide the pipe back on and then it wont stall because there wont be an air leak into the system with engine running spray whilst reving it up or keep the revs high otherwise the cleaner makes it stall.......
