Author Topic: Smoke from Steering Column please help  (Read 1759 times)
Offline tazistara
« on: 18 August 2007, 17:09 »
Well my old girl failed her MOT (mk2 gti 8v), but at 20yrs old she didnt fail on a lot i.e. 1. n/s reg plate bulb not working - easy, 2. o/s rear fog not in good working order - easy, 3. centre section exhaust system leaking exhaust gases - easy, now the poser 4. (pulsing) all position lamps adversely affected by the operation of another lamp ? thats the one im stumped on, and the fact that when i went to take her in to get exhaust done turned on ignition and thought a genie was going to appear as i had smoke coming from steering column - now that cant be right, so i would much appreciate it if anyone can help with this problem as i have a yr old little one that goes everywhere with me in this car and im very concerned that this could be a dangerous problem.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Smoke from Steering Column please help
« Reply #1 on: 18 August 2007, 18:38 »
does the car start since the smoke came? its likely to be bad earth as that was my problem ad my iggy switch had burnt out, im in a 1.3 and it was the earth on the front engine mount loose.. maybe soemthing gone in the stalks or?
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Mr Blue
« Reply #2 on: 18 August 2007, 18:46 »
I was going to say ignition switch. Happend to me
Offline tazistara
« Reply #3 on: 18 August 2007, 18:50 »
yes the car still starts first time even with the smoke, maybe i should think about getting rid although she has never let me down, but i need a car with having the wee one
Offline tazistara
« Reply #4 on: 18 August 2007, 19:01 »
just been out and started up the car, no smoke, this is weird, could this bad earth you were talking about cause the pulsing in the lights ? cos there must definetly be a bad earth somewhere and they wont pass it with the pulse
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #5 on: 18 August 2007, 19:44 »
The pulsing of the rear lights when using indicators is quite a common fault with VAG cars and easy to rectify. The cause is a corroded earth terminal in the strip connector in the back lights. What I have done to rectify the problem AND prevent it from happening again is to remove all the corrosion, degrease the terminal and then put a blob of solder on the corrosion damage, then file smooth. This was on an older Audi Coupe but they are much the same.
Offline tazistara
« Reply #6 on: 19 August 2007, 09:39 »
thanks for your reply but its not happening when using the indicators, its when main beam is on and you press the brake pedal, the indicators and the reverse lights pulse thats what the garage have said, i tested it and i cant see any pulsing when using lights and pressing the brake (maybe the old girl was having an off day lol) i love golfs and had a few mk2 gti's and the mk1 convertible but this is the first time i have had problems with electrics
Offline DarnPB
« Reply #7 on: 19 August 2007, 12:24 »
I still think it may be an earth terminal. Same symptoms as before. Its just that the service you are using, ie the lights, are earthing through another terminal other than the earth.
Offline Simpson
  • one day il learn
« Reply #8 on: 20 August 2007, 12:13 »
Yeash sounds like an earyn too clean all the light connectors up and put some grease on, also don't get rid due to a few niggles they all have them, easily sorted  :smiley:
i must buy a new car!
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #9 on: 20 August 2007, 14:12 »
This sounds a bit like a common problem on mk1's so worth a look at the wire (grey/blue i think :undecided: ) for illuminating the switches etc... when the lights are on which runs around behind the dash, it could be shorting out somewhere.
had that twice on mk1's, its really scary when the smoke turns to a red hot wire  :shocked:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
