Golf mk2
loose injector
Topic: loose injector (Read 646 times)
monkeyalan
loose injector
16 August 2007, 18:54 »
one of my injectors is very loose on my 16v.
am i right in assuming that it's probably the seal thats gone and they can be replaced without buying a new injector?
cheers.
EDIT : found this post.
http://www.golfgtiforum.co.uk/index.php?topic=54029.0
thats me to GSF tomorrow then.
should the injectors just pull out anway , just requiring a bit more force? don't wanna bust owt.
Last Edit: 16 August 2007, 18:58 by monkeyalan
DarnPB
Formerly Darnpistonbroke
Re: loose injector
16 August 2007, 19:08 »
Once disconnected, should just pull out. Don't use excessive force if it is stuck. A gentle but positive force with a twist should bring it out. If not, give it a squirt with silicone spray. (Dashboard cleaner like back to black)
Gambit
Forum addict
Re: loose injector
17 August 2007, 10:30 »
personally id order the seals from VAG they are better quality and fit than GSF items. also, get the upper & lower seals for the injectors
monkeyalan
Re: loose injector
17 August 2007, 11:11 »
i had to pick a temp sender up from ECP today so i ordered 4 of each from them.
Golf mk2
loose injector
