Author Topic: G60 steels centre caps  (Read 800 times)
Offline Robdub
  • Pearl grey 91 16v gone and missed
« on: 15 August 2007, 19:27 »
Hi just a quickie i just got some centre caps from vag 22quid inc nut caps but it would appear i need to trim the lugs that sit under the nuts anyone done this do you need to do all four or just a couple thought i`d ask b4 messing it up. :smiley:
cheers
Rob..
Offline pegasus
Re: G60 steels centre caps
« Reply #1 on: 15 August 2007, 20:58 »
you shouldnt need to trim the lugs off. uv obviously not pushed the centre cap on far enough...
1.8 20VT GTI
Offline Robdub
« Reply #2 on: 15 August 2007, 21:32 »
 Maybe but i dont think they should be that tight fella from vag i got em off reckoned they needed to be trimmed up as the proper centre caps are the disc type but i could be wrong if you force them on it would be a right pain getting them off. :wink:
Offline nealey
« Reply #3 on: 15 August 2007, 21:36 »
they are a bit of a nightmare to get on, you have to give them a good whack and they normally go on
Offline mattp1983
  • Keep it VAG :)
« Reply #4 on: 16 August 2007, 20:51 »
you kind of bend them in around and they click, its because they are designed for the 15" steels not yours, but they do fit I had some on mine. Just fiddly
1989 Golf GTI 8v Tornado Red <br />2004 Bora Highline TDI 180bhp Shadow Blue
