Author Topic: Cylinder head number  (Read 754 times)
Offline stanlec1
« on: 13 August 2007, 13:41 »
Hello,
I've got hold of a cylinder head for cleaning up - it's got:
45
026103373H
stamped on it.  Anyone one know if it's for the k-jet or digifant engine?  Is there any difference?
Cheers,
Chris
Re: Cylinder head number
« Reply #1 on: 17 August 2007, 17:58 »
Thats probably the casting number, I've not had much luck looking these up. it makes no odds either way which head you have, they will both fit.
The only real difference is the early ones had solid lifters, and the later ones had hydro.  Easy to check, if one of the cam caps is missing its a hydro head.  The other thing is that K-Jet & Digifant heads have different injector inserts, but you can unscrew them with a suitably sized allen key & swap over :)
