Author Topic: Front door panels  (Read 1714 times)
Offline Rob GTi
  • Watch out for Chav's
Front door panels
« on: 23 February 2004, 11:45 »
With regard to my message below relating to squeeks and rattles. I know this question has been asked before, but could you tell me - is it easy to remove the front door panels and lubricate the plastic/metal bits and tighten them up.
Cheers.
'51 Black 1.8T GTi - Totally standard - Except for a GTi badge on the front!!!!
kniterider
Re:Front door panels
« Reply #1 on: 23 February 2004, 14:02 »
easy matey had to remove mine when me windo reg broke. theres a few phillips srews and some torx ones then remember to lift it up then pull away to remove, put some silicon grease on any bits you think were making a noise and reassemble. easy ;D
Offline Rob GTi
« Reply #2 on: 23 February 2004, 14:09 »
Cheers, will try that later.
