Author Topic: Which Springs?  (Read 728 times)
Offline kkh120
Which Springs?
« on: 09 August 2007, 09:36 »
Need to replace the rear springs in my 16v. Just looking a standard replacements.
GSF -£25+v
Euro - £15+V
Any difference?
Forgot to ask, whats the ride height on standard springs?
Is lowering by 40mm a lot?
« Last Edit: 09 August 2007, 09:45 by kkh120 »
Mk2 8v and 16v.
Always looking for bits!
Offline dabill
Re: Which Springs?
« Reply #1 on: 09 August 2007, 09:54 »
lowering by 40mm on std shocks is ok, as long as you use decent springs. eibach etc... not gmax or anything halfrauds can offer.
40mm just takes the ride height down a little bit, looks alot better than standard, but doesnt really do too much to handling in my opinion.. but there again, i've only driven cars that have had the springs replaced with pants gmax.
my golf has shocks and spring set and it makes such a difference!
rob
noble tuned - and still not fast enough!
Offline stomper
Re: Which Springs?
« Reply #2 on: 09 August 2007, 10:29 »
Eibach 20mm or 40mm springs, which will firm up the ride and improve the looks, can be used with standard shocks if they are in good nick.
They are about £130 but are top quality.
2003 Black Magic Bora Sport 1.8T (180)
AMD remap
Milltek Cat-back exhaust
18" BBS RC's
Eibach 30mm Springs with Boge Shocks
Front and Rear V6 4Motion Valances
Re: Which Springs?
« Reply #3 on: 09 August 2007, 16:35 »
you'll only see a 10mm drop on your 16v, most spring kits are quoted from the carb MK2, and the 16v is 30mm lower than a carby :)
