Author Topic: Porsche 944 Turbo wheel into late Mk2  (Read 2622 times)
Offline Geeman
« on: 07 August 2007, 14:30 »
I have bought an '87 Porsche 944 Turbo steering wheel for my Jetta.
Unfortunately, it's for a small-spline steering column. The '91 Jetta I have has a large spline column. VW introduced a 'step-up' collar at a later date to 'upgrade' the steering lock security thing, so I've been told.
I can see the collar on the column that changes it from small to large spline., but... how the hell do I get it off without damaging anything?
All help and advice is appreciated!
Cheers,
G.
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
Re: Porsche 944 Turbo wheel into late Mk2
« Reply #1 on: 07 August 2007, 16:34 »
Use a Hub/Bearing puller on it, I threw mine away but now my mate wants one - how much do you want for it  :laugh:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
Offline Geeman
« Reply #2 on: 07 August 2007, 16:38 »
How much do I want for what?
The large spline collar, or the steering wheel?
« Reply #3 on: 07 August 2007, 17:46 »
The spline thing  :smiley:
my dub project:-
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
« Reply #4 on: 07 August 2007, 18:13 »
The larger diameter spline is just a sleeve which fits over the smaller one, was introduced in 89 I think. I took the one off my last golf to fit an earlier steerng wheel, did it using an old adjustable spanner tightened around behind the sleeve and a gear puller, pushing on the steering column. Came off ok, but I found it impossible to shift without the puller
Offline Geeman
« Reply #5 on: 08 August 2007, 09:19 »
Nearly set the car on fire last night I was so frustrated!
Had a hub puller, but I couldn't get the dame thing off. Had a hub puller, but nowhere to grip the arms onto. Even ended up taking the top section of the column completely out of the car and trying.
Grrrr!
Off to a breakers at lunchtime to take out a column from an early Jetta. Hopefully I'll be able to use this small splined column with my switchgear and solve the problem that way.
Then comes the horn problem... lol
« Reply #6 on: 09 August 2007, 16:24 »
thread the wheel nut on, then bash the column with a hammer ;)
Offline Ozz
« Reply #7 on: 09 August 2007, 17:26 »
I did this exactly the same, old adjustables are perfect for this job!
Mk2 Gti 8v
Offline Geeman
« Reply #8 on: 13 August 2007, 09:35 »
Put the nut on and whacked it a few times. Came off with minimal hassle.
Thanks for the tip!
G.
« Reply #9 on: 13 August 2007, 10:12 »
:cool:
Have to add I can't take credit for this one, was someone else on this forum who figured it out :)
