Author Topic: 9a identification  (Read 598 times)
Offline Philpy
9a identification
« on: 06 August 2007, 13:17 »
Im thinking of getting a 9a to replace the bottom end in my valver, where exactly is 9a on the block? Pics would be a massive help!
Thanks
Re: 9a identification
« Reply #1 on: 09 August 2007, 16:07 »
look for a 2.0 16v k-jet lump block out of a passat or corrado, and it'll be a 9a.  Find a 2.0 16v k-jet lump out of an audi and it'll be a 6a, which is same as 9a but with audi bits bolted on (sump, oil filter housing etc)
2.0 16v digifant out of a MK3 golf or seat will be an abf, which is a bit taller than a 9a or 6a (and a KR).
The engine codse is stamped on a flat area at the top of the block between cyls 3 & 4, but almost without fail this will have corroded away, so you'll need to use the sticker in the boot of the car or the inside cover of the service book.
