Author Topic: Ok bottom end part prices  (Read 881 times)
Offline Philpy
« on: 03 August 2007, 14:07 »
Im gonna do the shells on my valver in the hope I have caught the knocking early enough...
What bits do I need?
Ive been quoted this from VW at a discount price (Know someone there)
Shells £16.64 + Vat (full set)
Sump Gasket £15.77 + Vat
Sump bolts around £7
Oil Pump £91 + Vat  :shocked:
Big end bolts around £45
Do I need all this? DO those prices seem ok?
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Ok bottom end part prices
« Reply #1 on: 03 August 2007, 14:32 »
The head bolts and gasket set you DEFINATELY need. Its always a good idea to change the oil pump but I think you will find it cheaper from GSF. Sump bolts you don't really need unless you have lost a couple. It may be a good idea to replace the big end bolts too, but not essential. More for peace of mind than anything else.
I bought my big end bolts for about 10 Euros (more or less) (I live in Spain) so £45 seems a bit much. Again, look at GSF for all the items you need. You don't need to spend that much.
VeeDubGTI16v
« Reply #2 on: 04 August 2007, 11:13 »
i got the oil pump from gsf, was 40quid, and if i were you id use a windage tray from a mk3 diesel instead of the sump gasket, which was 25quid from gsf.
Offline richard s
« Reply #3 on: 05 August 2007, 21:43 »
what does the windage tray do and will it fit a mk3 2.0 bottom end
