All sorted
Been busy on the car this weekend but theres only 3 things that I did which solved the problem. 1st was tighten the power steering belt properly ( f**king adjuster bolt snapped on me which took a few mins to sort) which Im sure didnt solve the idling problem
2nd was took the inlet hose off and blow a couple of squirts of carb cleaner down the main unit. 3rd was tighten up the inlet hose jubilee clip extra tight
Now ticking over sweet and a pleasure to drive
Compression checked which told me the rings were good
Timing now checked
Oil flushed and renewed, new filter
New air filter
New plugs
But ive still got a problem with smoking and its got worse since someone (not me) tried to help and adjusted the co screw. Next job is to sort that out using rubjonnys thread.
Im deff finding my way round the car now which will help with future problems of which im sure there will be
