Author Topic: clutch cable  (Read 1492 times)
Offline m4nesh
clutch cable
« on: 21 February 2004, 22:50 »
howdy!
My clutch cable needs replacing as it is not adjusting correctly :-\. How easy is it to replace the cable and where do you think I can look up info for doing the job.  Haynes manual is not very clear.... ???
cheers
Manesh
Offline dubslug
Re:clutch cable
« Reply #1 on: 21 February 2004, 22:54 »
clutch cable is fairl easy to do, follow cable to clutch you will see it goes in to block, jack the car up and look from underneath, it has like a plate which just unclips with a few bits of rubber to, once this is disconnected u then need to goto ur clutch pedel and un hook it from there and feed it through into ur engine bay, old one out new one in but in reverse order, hope it makes sense and helps, not a hard job to do
1992 pearl grey 8v
Offline richandhazel
Re:clutch cable
« Reply #2 on: 21 February 2004, 23:01 »
I'd also recommend going for the non-auto adjusting type..........cheaper and more reliable.
Hey Rik I meant to ask, what happened to your old Golf? Siezed crank or something? Why did that happen? Lack of oil?
Offline m4nesh
Re:clutch cable
« Reply #3 on: 24 February 2004, 17:58 »
just had the clutch cable replaced its an auto adjusting one.  The thing is that the 91 8v is a bit edgy when you lift the clutch the car vibrates a little, feels strange and i've noticed that selecting gear is more stiff than usual.
anybody got any ideas cause i cant think of anything ???
Manesh
