Author Topic: Subwoofer in passenger footwell?  (Read 6464 times)
Offline Heyho
Re: Subwoofer in passenger footwell?
« Reply #10 on: 30 July 2007, 20:38 »
In terms of sound quality, a sub in the footwell will, if anything sound better than in the boot, as it will be more "in time" with the rest of the speakers.  Don't be concerned about it drowning out the other frequencies - that's what your gain knob is for. :wink:
I should think that you could easily build a sealed enclosure for a good 10" or 8" driver that will fit neatly up under the shelf.
Offline mk2mark
« Reply #11 on: 31 July 2007, 08:32 »
What about a 12" ? :shocked: I'll post up pics when I'm done, there's a surprising amount of room!
Offline Dubster2
  • Dubs forever!
« Reply #12 on: 01 August 2007, 01:23 »
As said before. where would he passenger put their legs?! Would be a nightmare on a long journey! Also would you mind the speaker being kicked and knocked as that's sure to happen with so little leg room!
Offline mk2mark
« Reply #13 on: 01 August 2007, 11:42 »
It's hopefully not going to take any more room than the little shelf thats there at the moment, it may not work but I think I can do it.
Offline monzablue16v
« Reply #14 on: 01 August 2007, 22:57 »
Put a couple of 8" subs in a custom door build it will sound the nuts and won't get in the way too much :)
Offline Heyho
« Reply #15 on: 03 August 2007, 19:05 »
If you want to have a go with a 12", then why not!  I was considering the size of the enclosure!
What you need to consider is that the larger the sub, the louder it will be, and as you'll be that much closer, and with no obstructions, it won't need to be as loud as it would when in the boot.  Best to match the driver to the amp you'll be powering it with.
I'd go with a 10" in a sealed enclosure, but do what you want and make sure you post some pics.
Offline mk2mark
« Reply #16 on: 06 November 2007, 15:50 »
Pics:
Sorry about the crappy photo quality, the photos make it look awful too! Soundwise it's great, there's no boomy drone bass, just clear punchy accents which is exactly what I wanted - just as well because with the small enclosure I don't think I was going to get anything else. It really is far more subtle than it looks, people only notice it when their legs start vibrating!
Offline vw-bob
« Reply #17 on: 06 November 2007, 16:12 »
just wait until all your connections are vibrated loose behind the dash. good luck finding them  :smiley:
Offline b4rks
« Reply #18 on: 06 November 2007, 18:07 »
Fair play chap.
I put an 8" where the glove box was once in a citroen ZX.  Along with amped front speakers, a healthy set of ported 12s in the boot and a decent headunit it sounded utterly amazing.  You're on to a winner...... but you already know that :)
Offline mk2mark
« Reply #19 on: 06 November 2007, 18:35 »
Well it works for me, I need the boot in this car for the goalie gear. And now I have realistically high quality sound (for a car) so I'm happy. It took me a long time to decide if it would be worth the extra kilos, adding weight to a car is not my thing - ever, but I'm glad I went for it.
Thanks for the sage advice bob, I'll be sure to keep a close eye on my connections.
