Author Topic: PAS belt wont fit  (Read 610 times)
Offline logix42p
PAS belt wont fit
« on: 29 July 2007, 17:16 »
Right i have just taken my old belt off as it was screaming. Now the new belt is the same length but i cant get it over the pulley. I have moved the PAS pump up but the two pulleys are literally touching each other and it wont fit. Have i missed something?
Its on a 90's spec digifant 8v.
« Last Edit: 29 July 2007, 17:33 by logix42p »
Offline logix42p
Re: PAS belt wont fit
« Reply #1 on: 29 July 2007, 18:18 »
All sorted just needed to stop being a pussy and put some back into it.
Offline paultownsend
« Reply #2 on: 29 July 2007, 19:35 »
is there movement in your pump when changing the belt?
loosened all my bolts and doesnt seem to want to budge!
Offline logix42p
« Reply #3 on: 29 July 2007, 20:24 »
yeah, i undid the two bolts either side of the bracket and with a bit of pursation it moved but the prob was it couldnt get it to move far enough. However in the end i managed. So yours might need a little tap with a rubber mallet or something as it might have rusted onto the bracket or soemthing would be my guess.
