Author Topic: Upgrading master cylinder & servo in my MK1 Gti  (Read 3491 times)
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« on: 28 July 2007, 20:15 »
Hi all i read up some info i am wanting to upgrade my cylinder and servo to a mkII 16v one. the info i found was:
Get the Larger master cylinder ( 22mm ) and servo from the 16v or a passat.
This bolts more or less into place, you may need to space the Servo out a bit more on the bracket than the original mk1 item, a few washers/around 4mm will be fine.
You will also need to T peice the brake lines, this is no big issue.
What, how and where do i T piece ow and where can i get brake pipe T pieces from, do unipart or any other service parts supplier have them or are these specialst sellers only?
This T piece business part is the bit i need details of so i can go ahead with the upgrade.  :undecided:
Any people got any pictures or info please i would be very grateful.  :nerd:
Many thanks vag heads!
Dan
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: Upgrading master cylinder & servo in my MK1 Gti
« Reply #1 on: 29 July 2007, 01:12 »
Any Motor spares place will have these... I've upgraded my cab to this set-up have a look at this picture to see what they looks like..
If you do this conversion, these links might help you..
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=13901
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=4004
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline grungeisdead
« Reply #2 on: 29 July 2007, 20:36 »
two good links there, and a spot on pic to help you out...
madone - see the cars progress on ed38 and shes gonna be amazing :) well done!
