Author Topic: cleaning and polishing that engine bay?  (Read 4796 times)
Offline samco-jack
« on: 21 February 2004, 17:09 »
Hello buddies,Whats the best way to clean an engine bay and get one of those cover car shine's
oh yer,
 i'v a small hole in the second section of my exhuast,and the breather on the crank case is lose am i loseing power because of it?
VeeDubGTI16v
Re:cleaning and polishing that engine bay?
« Reply #1 on: 21 February 2004, 17:45 »
take your engine apart, chrome everything, buy 7 bottles of brasso, polish it for 3 days solid and then put it in your garage and tow it to a few shows a year ::)
Offline bigkev750
« Reply #2 on: 21 February 2004, 19:32 »
ouch thats gotta hurt :)
Offline lewis
« Reply #3 on: 21 February 2004, 21:37 »
You could try steam cleaning it. That could help get some of the surface muck of then use a bit of elbow grease. Don't know how good it would come up as I always worry about 14 year old electric and water mist coming together. Maybe getting some proper engine paint that will take the heat and paint the rocker cover and anywhere else that you can reach but make sure you clean it down properly first. You should take the engine out really to paint it properly (year right). Maybe some sort of brush on aluminium cleaner on the intake manifold and other bits like that. Shrink wrap any exposed wires and change any rusty hose clips. All depends how much money you want to spend on it as to how far you go.
VeeDubGTI16v
« Reply #4 on: 22 February 2004, 11:51 »
i heard steam cleaning is bad for all the hoses, perishes them.
kniterider
« Reply #5 on: 22 February 2004, 13:02 »
depends on how you do it!!!, if you jet steam in all electrical bits your asking for trouble, dont think steam will perish hoses but cleaning em with chemicals etc will (unless u have silicon hoses ie:samco etc), i use a degreasing chemical from work called 'jizer' give it a good going over with that then gently wash off with hose pipe(avoiding electrics if poss) this stuff is biodegradable so its ok to go down the drain, dunno if you can buy this stuff but its better than gunk etc ;D
VeeDubGTI16v
« Reply #6 on: 22 February 2004, 16:51 »
degreasing chemical called jizer ???
ok im gonna be grown up and not make a joke ;D
Veedubgt18v
« Reply #7 on: 22 February 2004, 17:27 »
The breather will affect your idle. is it an 8 or 16v? as for the exhasut it wwill blow a bit but dont worry unless it gets well big and loud. you may notice it seems worse in the cold tho
Offline samco-jack
« Reply #8 on: 22 February 2004, 19:58 »
8v
Blue MK2
« Reply #9 on: 22 February 2004, 21:06 »
Mr Muscle over cleaner on a hot engine should do the trick ;)
