Author Topic: Dent removal  (Read 2433 times)
Offline Robdub
  • Pearl grey 91 16v gone and missed
Dent removal
« on: 27 July 2007, 16:40 »
Hi all i have a dent in my driver`s side front wing about 4 inches in diameter
its not creased and looks to be easy to pop out maybe  :undecided:
I was thinking of buying one of them suction cup things and giving that a go
or would it be better to knock it out from the other side, it looks like i an get
to it from the access panel next to the airbox.
Any advice or suggestions would be appreciated.
thx
Rob.
Offline helios
Re: Dent removal
« Reply #1 on: 27 July 2007, 16:53 »
I had a dent on the bonnet of my mini cooper roughly the same size a few years ago.I got a large plunger and used it on a really hot day when the bonnet was really hot.Pressed it down once and once only and let it pop up by itself,which took about 10 min.It turned out perfect.The thing is I also know someone who done the same, the dent came out but there was a small hairline crack on the paint.If you have a few bob get it done professionally but if not dont force the plunger,just press it down once and let the vacum do the job.
Offline Robdub
Re: Dent removal
« Reply #2 on: 27 July 2007, 17:00 »
 thanks for the info, i might try the plunger technique it seems to shallow to fill
 and spray up hopefully it will just pop out without leaving paintwork damage.
Offline helios
Re: Dent removal
« Reply #3 on: 27 July 2007, 17:02 »
Make sure the panel is warm as the metal bends better and dont by any means pull the plunger up when it is down,it will release itself in time,good luck
Offline monkeyalan
Re: Dent removal
« Reply #4 on: 27 July 2007, 19:51 »
theres a clip somewhere ont netwhere someone pops a shallow dent by heating the back of the panel with a hot air gun then quickly blasting it with co2.
Offline Robdub
Re: Dent removal
« Reply #5 on: 27 July 2007, 20:45 »
I watched it earlier the guy used a hairdryer to heat up the dent and then blasted it
with compressed co2,the stuff you use to blow the crap out of your pc.
link to the vid its  worth a look :nerd:
http://www.metacafe.com/watch/501379/remove_car_dent_with_airduster/
Offline VW_valver
Re: Dent removal
« Reply #6 on: 29 July 2007, 10:55 »
Would you be able to do the same thing with a co2 fire extinguisher as I can get hold of them ten a penny  :smiley:
Cheers,
Andy
Offline monkeyalan
Re: Dent removal
« Reply #7 on: 29 July 2007, 12:00 »
i don't see why not.
Offline VW_valver
Re: Dent removal
« Reply #8 on: 31 July 2007, 16:48 »
Brilliant, im going to give it a try then  :grin:
Cheers,
Andy
Offline Retrocool
Re: Dent removal
« Reply #9 on: 31 July 2007, 16:50 »
post some pics up of the results when you do it... :smiley:
