Author Topic: head gaskett gone????  (Read 2198 times)
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
« on: 20 February 2004, 20:08 »
If i let my water run low i find a bit of gunk on the cap, obviously i should just stop lettin it run low but the real worry is that i found a big lump of it on my pannel filter, near the in take????
The car never over heats and i have no other problems, any ideas???
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
Offline mk1
Re:head gaskett gone????
« Reply #1 on: 20 February 2004, 20:24 »
If i let my water run low i find a bit of gunk on the cap.
Which cap, if is is the oil cap, maybe nothing to worry about. Condensated oil fumes can make a mess on the filter at this time of year.
Where is the water going is what I would be looking
at, it you had a big head gasket problem the oil in the sump will be contaminated. Does the car missfire when you first start it?.
Steve.
Offline gti fly bye
« Reply #2 on: 21 February 2004, 17:03 »
no, she takes a while to turn over first thing but runs fine, i just replaced the heater matix so i will check those pipes, its the gunk on the air filter pannel that really worrys me! :(
Offline mk1
« Reply #3 on: 21 February 2004, 23:35 »
Look for a external coolant leak as you should not loose coolant. A bit of "sneeze" on the air filter does'nt mean the engine is toast.
Steve.
Offline gti fly bye
« Reply #4 on: 22 February 2004, 00:44 »
Cheers mate, i'll stop cackin my pants now :D
Offline moonsta
« Reply #5 on: 22 February 2004, 01:19 »
 :) do you only use it for short journeys?? 'cause if it ain't getting time to warm up properly then you will get gunge where the condensation accumalates................... ;)
Drives '96 Polo 6N and '85 Mk Golf Gti...
