Author Topic: Headlight problem  (Read 797 times)
Offline perryqhill
Headlight problem
« on: 24 July 2007, 22:30 »
Tonight I've been messing aroun d putting some new door pocket speakers in. During this time I've had some of the trime out and the wires around the fuse box have been exposed - possibly I've poked around one or two of them.
When putting my radio back in the slot, I blew a fuse - no problem, I had a few of the fuses out (a lot actually) found the blown one and replaced it.
However when checking I saw that the indicator/hazards weren't flashing. So I had a bit poke about in the fuse box and they were working again [:s]
Later I've just been out in the car and I've found that again the hazards weren't working and again I cured it, however also I noticed that the sidelights work and full beam works, however normal mean doesn't work and yet everything else seems to.
So far I haven't been able to find anything blown (not even sure what fuse number they should be) - is there anywhere in particular I should be looking?
