Author Topic: Cat convertor & Back box?  (Read 3516 times)
Offline immortalkhalsa
« on: 24 July 2007, 11:43 »
Hi Guys,
just FYI - i have a golf mk4, 1999, gt tdi 110bhp, AHF code
i was wondering if someone would kindly post a diagram of my exhaust setup with part numbers for the cat and back box as i need to buy these.
also i was wondering if you knew of a good place i could pick these up from.  they need to be replaced as my turbo has blown and i am told that it has affected the above.
Re: Cat convertor & Back box?
« Reply #1 on: 24 July 2007, 22:32 »
guys, any ideas? is it worth me thinking about a milltek full system....any links to one please?
Offline Ridg
  • TDI - Soot Happens!
« Reply #2 on: 25 July 2007, 10:02 »
you can get an exhaust from http://www.jabbasport.com/product_detail.asp?CategoryID=27
i'll try and get you some images up later with the VAG part numbers.
you can check them yourself on www.vagcat.com
you'll have to register but its free
« Reply #3 on: 25 July 2007, 11:33 »
thanks bro, just had a looksie at the link and this is what i found that was the closest to my car?
Milltek MK4 1.9TDI PD Exhaust System
* With centre silencer (quieter)
* Twin round 76mm tailpipe
* Pipe diameter 69.85mm (2.5")
* Also available with discrete tailpipes
* REQUIRES 4-MOTION REAR VALANCE!!£333.00 inc VAT
just some questions, i hope u can help with
1 - its the only one i could find that was similar to my car.  would this be the right one as my golf is not a PD?
2 - also any cutting etc required, direct replacement? i am looking to get a very discrete and quiet one so not the twin round pipe...this is possible right?
3 - what are the benefits of this spec milltek compared to the standard exhaust system?
much appreciated
Offline Ridg
« Reply #4 on: 25 July 2007, 11:55 »
can't really say if it would fit, would probably say it wont though
this thread will interest you
http://www.golfgtiforum.co.uk/index.php?topic=59529.0
pretty certain you two have got the same engine.
you should be able to get a discrete back box, the same style as the current one twin exit bent down, best bet is to give jabba a call and see what they say.
« Reply #5 on: 25 July 2007, 22:51 »
ok guys i paid £500 for a full system which include the cat back system and the de-cat pipe, is this an ok price.
do i have to get a custom map to benefit off my new Milltek, will the car be sloppy? what can i expect with the change over when i collect my car on the weekend without any custom map?
the reason i ask is that i am very much into my superbikes after a full system change they often run very off untill they get remapped. just wondering if its the same?
