Author Topic: Super-charge?  (Read 909 times)
Offline junglebunny
Super-charge?
« on: 24 July 2007, 09:25 »
I've got a 1.8 8v GTI mark 2 and I want to get it supercharged. Could someone tell me how much more brake horse this would give me? And if anyones done it how much roughly would I be looking to spend? I love my Golf but am after abit more va va voom.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Super-charge?
« Reply #1 on: 24 July 2007, 10:08 »
Think carefully before you go ahead and supercharge. There are a number of things to be taken into consideration. You can't just buy a supercharger, whether it is a turbo or an engine driven one, and simply bolt it on. The present compression ratio (CR) of your engine is too high for it, so you would need to lower the CR. This means changing the pistons.
Because you are supercharging, the combustion temps rise, so therefore you need pistons to be able to take the higher burning temps. You would also probably need to fit an external oil cooler and fit a larger radiator to take away the excess heat.
The G60 engine is a supercharged unit and it is almost entirely different to the normally aspirated engines that Golfs usually have. This because during development of the modification stages done by VW to make the engine supercharged, most things were modified or changed including the cam shaft, the head, the pistons, the injection system, etc..
Whilst it is possible to supercharge your engine, it would be better if you just bought a G60 and then service the supercharger. Cheaper anyway.
Look at the projects part of this forum and look up GTI Joe's project. He is turbo charging his engine, and the amount of work to be done is considerable.
« Last Edit: 24 July 2007, 10:12 by Darnpistonbroke »
Offline j_s
Re: Super-charge?
« Reply #2 on: 24 July 2007, 11:42 »
Find a complete G60 lump with all ancillaries etc, be much easier and cheaper in the long run.
James
Offline keefusg60
Re: Super-charge?
« Reply #3 on: 24 July 2007, 13:23 »
For £4k, you can have my G60...................  :wink:
Offline junglebunny
Re: Super-charge?
« Reply #4 on: 24 July 2007, 15:14 »
I'm going to have to see if I can get a bit of money together. That is my dream car. Love the colour as well.
