Author Topic: what sat nav gps etc do you have? what ones to buy  (Read 3717 times)
Offline Britman
Hi im going to get a sat nav, which ones do you have and what one sare good and what prices are good for ones you have, how do they work do i need to subscibe etc is it worth looking at used one son ebay or better to by new?
and info much appreciated, thanks
i dont get all the specs and what is neccicery and what not ive not looked into them yet at all so dont know where to start
not sure how much to spend
just realised its might be in wrong catergory should be in nononsence  i think
« Last Edit: 23 July 2007, 22:52 by adrenaline »
Offline lewis1641
  • stuck in the 90's
Re: what sat nav gps etc do you have? what ones to buy
« Reply #1 on: 23 July 2007, 23:21 »
hi. sat nav works by a minimum of 3 satelites locating you in relation to the rest of the earth. the satnav unit carries maps. using the 2 it knows where you are and it has the maps to get you to where you want to go.
i have a navman icn520 which is hetting a bit long in  the tooth but i like it s it is quite slim so stores away easily. you can pick these up for less than 100 quid now. the work van has a navman n20 i think and that is an entry level system which is easy to use.
i have some friends who use tomtom and they are a bit more expensive but do seem better and a bit easier to use.  if you are on a budget go for the n20. i think ebuyer are doing them pretty cheap at the minute. if you have a bit more cash to spend go for the tomtom.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #2 on: 23 July 2007, 23:53 »
Tom Tom all the way.. http://www.halfords.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10651&storeId=10001&langId=-1&productId=260869&p1=38270&p2=31284
Ive been using this system for a few years now, and can honestly say, i cant fault it!
Tom
Offline kuk sool
« Reply #3 on: 24 July 2007, 08:40 »
I had a tom tom 500 till it got nicked....which was awsome!!!!
i bought the road angel as a replacement and it took about 5mins to load up (i timed it) it was rubbish!!!
Instead i bought the Tom tom one!!!! EXCELLENT and fits in your pocket like a wallet so you take it anywhere with you. It also tells you the speed limit in every area!!!
Go tom tom and never look back!!!!
Offline Britman
« Reply #4 on: 24 July 2007, 10:18 »
thanks a lot, I will go for a tom tom, what isthis one i sit betternthan 500 what i sth eorder of number in term or bottom of range to top?
tom tom one
http://cgi.ebay.co.uk/TOM-TOM-ONE-SAT-NAV-SATELITE-NAVIGATION-SYSTEM_W0QQitemZ180140554320QQihZ008QQcategoryZ75327QQrdZ1QQcmdZViewItem
Offline Britman
« Reply #5 on: 24 July 2007, 10:36 »
is the 510 710 910 better than the one v2? the 910 seam to fetch a lot
ive seen the tom tom one is 199 on there site and the 510 is 279 and goes up in price for 710 910 etc what the difference? :huh: why i sthe one cheaper is it not a sgood look bulkier not sure why its less features look similar
« Last Edit: 24 July 2007, 10:41 by adrenaline »
Offline AlanD
  • MK5 2.0T 16v
« Reply #6 on: 24 July 2007, 11:32 »
I borrowed a friends TomTomOne when I drove down to Newquay and thought it was fantastic. I liked the way it tells you what the speed limit is on the road you are driving on.
Offline jv
  • Administrator
« Reply #7 on: 24 July 2007, 12:43 »
If you look on http://www.tomtom.com/products/category.php?ID=0&Language=1 it tells you the differences. I have a 910 and think it is superb if a bit on the bulky size - you can't exactly put it in your pocket!
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Britman
« Reply #8 on: 24 July 2007, 13:20 »
i see the 510 710 910 are all similar, the higher ones have more maps of us and few other things but i could not see why the "one europe" model was £80 less ? than the 510 model, maybe its got some extras i missed will have to compare them again
« Last Edit: 24 July 2007, 13:22 by adrenaline »
Offline jv
  • Administrator
« Reply #9 on: 24 July 2007, 17:37 »
910 is hard drive based not memory cards (space for mp3's etc if you want to) has maps of europe and the US, plus has some funky speech engine so it can read out all the road names.
Buy site stuff!
