Author Topic: intermediate shaft timing  (Read 988 times)
VeeDubGTI16v
« on: 22 July 2007, 19:06 »
im swapping the cambelt and have discovered that there is no mark on the intermediate shaft pulley! is there another way of timing it? i knew i should have used tippex :laugh:
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
Re: intermediate shaft timing
« Reply #1 on: 22 July 2007, 19:51 »
i think there's one on the reverse of that pulley aswell mate.
Offline richard s
« Reply #2 on: 22 July 2007, 20:50 »
if its a 8v there should be a mark on your dizzy where rotor arm lines up to
also if you look in maintenance section there is a item for tuning digifant and this tells you how to set up correctly hope this helps
Offline jammac
« Reply #3 on: 23 July 2007, 19:16 »
mine had two marks!!!! one was a dot on a tooth and the other was a groove cut inbetween 2 teeth.
ITS A TRAP!
« Reply #4 on: 26 July 2007, 13:30 »
ignore the intermediate shaft marks, line up the rotor arm to the mark on the dizzy :)
The reason the intermediate shaft & cam pullies have 2 marks is because they are actually the same part, on 1 side is the mark for the intermediate shaft, the other side has the cam mark :)
VeeDubGTI16v
« Reply #5 on: 26 July 2007, 19:44 »
is that for the 16v?
« Reply #6 on: 26 July 2007, 23:11 »
with a 16v it matters even less since the only thing driven off the intermediate shaft is the oil pump, the dizzy runs off the cam :)
VeeDubGTI16v
« Reply #7 on: 27 July 2007, 19:05 »
yeah was gonna say the intermediate shaft doesnt affect the dizzy. nice one john.
