Author Topic: solid mount bolt length??  (Read 2281 times)
Offline rowlers
  • I'm back - MK7 GTI
« on: 22 July 2007, 12:26 »
going to be fitting my solid front mount this week (ta joe!)
before I take it all to bits and then have to go to B&Q fot the bolts I'd like to get them before I start! :wink:
So can someone who has recently fitted theirs can you let me know the length of the bolt I need?
ta very much!
Offline herbster
Re: solid mount bolt length??
« Reply #1 on: 22 July 2007, 12:37 »
 :laugh:  :laugh:  :laugh:  :laugh:  :laugh:  :laugh:   :laugh:  :laugh:  :laugh:
B&Q  :grin:  :grin:  :grin:
Why buy a bolt that will just get the job done, get the correct bolts to do the job right!!!!   :smug:
Most old stlye motor factors will be able to help, at least then you know the shank and the thread is correct for the job, if the job is done with a couple of threads inside a mount then excessive wear could occur, especially as the mount is going to be solid, movement will occur no matter how solid, then if you know the shank(shoulder) of the bolt is taking the movement wear will minimal.   :wink:
FAB is my life and the CABRIO's the wifes!!!!
Offline rowlers
« Reply #2 on: 22 July 2007, 14:53 »
which is why I need to no the the length that I need, otherwise I might end up with only a couple of threads!!!
As long as I get the correct length and thread it doesn't matter where I get the bolt from!
Offline cняis
« Reply #3 on: 22 July 2007, 15:49 »
^ what he said, a bolt is a bolt, as long as the length and thread are right  :wink:
Offline herbster
« Reply #4 on: 22 July 2007, 17:00 »
Really?  :sad:
You try telling that to a bolt manufacture'r!
Are you gonna use a 8.8 or 10.4 graded bolt, stainless or mild, locking nut or spring washer, metric or unified?
If the hole is 12.5mm diameter are you really gonna use a 12mm bolt?  :shocked:
Offline rowlers
« Reply #5 on: 22 July 2007, 18:22 »
eff me - forget I asked!
I'll find out the length and post back in case any one else would like to know!
Never ond I think I'll just put a self tapper in! :evil: :evil:
Offline Ben Lessani
« Reply #6 on: 22 July 2007, 19:37 »
Hi dude, some useful replies there  :shocked:
http://www.golfgtiforum.co.uk/index.php?topic=49436.msg487594#msg487594
Check that post, I don't specify length of the bolts, but the lengths were roughly:
Top Bolt - 1.5" Length (1.5 Pitch) M10 17mm - Original from old mount
Bottom Bolt - 2" Length (1.5 Pitch) M10 17mm
Bottom Bolt - 1" Length (1.0 Pitch) M8 13mm
I used some bolts I had lying about, but you want decent high tensile stainless steel bolts.
Offline rowlers
« Reply #7 on: 22 July 2007, 19:51 »
why thank you good man! Now I have some figures to work with! :wink:
I'll get the bolts 2moro and get it fitted!
Offline richard s
« Reply #8 on: 22 July 2007, 20:45 »
how much was the mount and where from cheers
Offline JMallows
« Reply #9 on: 22 July 2007, 23:03 »
why not go to VW for the bolts?? Anywhere is better than B&Q!!
A clever person solves a problem. A wise person avoids it.
