Golf mk2
Sunroof leak
Topic: Sunroof leak (Read 1231 times)
dannythomas752
GTI forum regular
Sunroof leak
18 July 2007, 10:46 »
As of this weekend my sunroof has a strange leak, it only seems to leak when heavy rain falls, if it is light it is ok. The water only seems to be on the black trim around the inside of the sunroof that keeps the headliner in, does anyone have any ideas what is causing this and a rectification for it
Thanks
Gambit
Forum addict
Re: Sunroof leak
18 July 2007, 11:10 »
are the front and rear drainage tubes working?? test them by pouring water into the sunroof runner tracks.
dannythomas752
GTI forum regular
Re: Sunroof leak
18 July 2007, 11:13 »
Ok ill have a look at that, if they aren't how would i sort it out?
Gambit
Forum addict
Re: Sunroof leak
18 July 2007, 11:27 »
you need to clear them out somehow - never had to do it myself!
clipperjay
Re: Sunroof leak
18 July 2007, 16:48 »
Best thing is to get compresed air through the top and a long stick bellow the A pillar to unblock the drain pipes that run throught it. A PILLAR is where I would strip off first then you can see the drain pipes. Or it could be the sunroof seal is it cracked and perrished around the roof door?
Jay
http://www.golfgtiforum.co.uk/index.php?topic=170521.0
http://www.golfgtiforum.co.uk/index.php?topic=55336.msg427955#msg427955
gibby
Forum addict
Champions of Europe,ooh ,just the five times then!
Re: Sunroof leak
19 July 2007, 00:00 »
There's a bit on this guide about the sunroof, but not a lot.
http://www.matey-matey.com/leak_prevention.shtml
I would also get a new sunroof seal if it's on it's way out. VW still do them or try
www.gpcvwaudi.com
......now officially dubless.
nunny
Re: Sunroof leak
Reply #6 on:
19 July 2007, 21:46 »
sounds like the drainage pipes, mines was blocked up on one side & it was a nightmare when it rained, the pipes exit behind the back bumper, i pulled mine out into the boot & got some wire up it & loads of crap came out, its not a hard repair, just very fiddly getting the old tubing back through the holes! Theres loads more info on this forum about it. Good Luck!!!
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Sunroof leak
Reply #7 on:
26 July 2007, 13:16 »
check inside the front door jambs 1st, theres a cutout in the wing where the drain tube should pass thru, if a wing has been replaced sometimes this gets pinched.
Golf mk2
Sunroof leak
