Author Topic: Bottom Radiator Hose Pipe  (Read 979 times)
Offline SpanishGolfGTI
« on: 14 July 2007, 12:41 »
Hi all,
Just got myself a Golf Gti here in spain its a 1993 Mk3, could anyone tell me the easiest way of replacing the bottom radiator hose pipe, as its developed a slight leak, either wear and tear or the hot sun, anyways its got to be replaced.
Thank you
Andy
Offline xzoex
Re: Bottom Radiator Hose Pipe
« Reply #1 on: 14 July 2007, 17:28 »
you could replace it or get some rubber weld to judt repair it,
I think its just a case of undoing the jub clips with a flat hed screw driver then sliding the new hose on and tighting back up
Hope this helps
Zoe x
Offline Simpson
  • one day il learn
« Reply #2 on: 23 July 2007, 21:04 »
just get a new one, i would think the seal would break eventually, yeah easy job either as Zoe says or get some good grips and squeeze the clips and slide clips off depending what type you have? where in Spain you live by the way?
i must buy a new car!
