Author Topic: Drivers side foot well leeking!!  (Read 780 times)
Offline xzoex
« on: 09 July 2007, 13:31 »
Hi every1
I cant find where the water is coming from its a mistery lol any common leaks bu the pedal box?
Thanks in advance Zoe x
Offline Agreeable Slick
  • Unit
Re: Drivers side foot well leeking!!
« Reply #1 on: 09 July 2007, 13:41 »
You need to check your heaters are all working, first as it is usually the heater matrix that dumps a load of water into the foot well, if that is fine then check the drain holes on the scuttle panel by the A frame are all free of dirt and muck, as they will over flow and the water comes inside the car.
Offline xzoex
« Reply #2 on: 09 July 2007, 14:02 »
Thanks slick  :smiley:
  • Unit
« Reply #3 on: 09 July 2007, 14:07 »
 :cool:
Offline gibby
« Reply #4 on: 09 July 2007, 17:31 »
I'd put money on the door membranes behind the door cards myself, common problem and had this on my Rallye over winter. :cry: Check this link out http://www.matey-matey.com/leak_prevention.shtml and it will tell you all you need to know. :wink:
......now officially dubless.
