Author Topic: wiper dont work  (Read 1658 times)
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
wiper dont work
« on: 18 February 2004, 01:56 »
hi, my rear window wiper doesnt work and its not a fuse :(
VeeDubGTI16v
Re:wiper dont work
« Reply #1 on: 18 February 2004, 11:19 »
you need a new motor :)
Blue MK2
Re:wiper dont work
« Reply #2 on: 18 February 2004, 11:33 »
nice golf mate 8)
Tried and tested the wiring at the motor end?
Offline marcogolfo
Re:wiper dont work
« Reply #3 on: 18 February 2004, 11:35 »
i'll give it a whirl, cheers mk2
Offline mpgscott
Re:wiper dont work
« Reply #4 on: 18 February 2004, 18:37 »
My rear wiper was the same and it turned out to be a build up of rust on the actual Mechanisim.
Take the motor off the mechanism and try it if the motor works clean the part that goes through the metal off the boot with emery paper and grease and oil it.
Mine has been ok for about three months now.
1996 VR6 Highline
2007 Aprillia Tuono
Offline JMallows
Re:wiper dont work
« Reply #5 on: 18 February 2004, 23:17 »
While these are valid points, and worth looking at. I would almost bet that the motor is fine. It could be the second problem of the rust, but more likely is that where the boot opens and closes over like 15 yeras, the wires in the section between boot and car snap. I say that this is more likely, because i have heard that this is a common problem. Take off the rubber from the left hand side of the boot opening (at the top as you look at it when the boot is open) and check the wires. If it is that, you could either replace the whole lot, or just stick a new piece of wire in between the break. Hope that one of these is the problem, as they are all easy to fix...
A clever person solves a problem. A wise person avoids it.
