Author Topic: Running to rich  (Read 2956 times)
Offline xzoex
Running to rich
« on: 08 July 2007, 22:12 »
Hello all  :smiley:
Does any 1 no how to adjust the mix as its running to rich?
Thanks in advance Zoe x
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: Running to rich
« Reply #1 on: 08 July 2007, 22:37 »
which engine?
Offline xzoex
Re: Running to rich
« Reply #2 on: 08 July 2007, 22:50 »
its MK2 1.6 Driver  :smiley:
Offline KINGS>
  • Watch out for the guns.....
Re: Running to rich
« Reply #3 on: 08 July 2007, 22:58 »
zoe, if its rich then the carb needs setting up, i would take off the airbox etc first and give the carb a really good spraying with some carb and choke cleaner first... if this doesnt work then get it set up on a gas analyser  :cool:
Offline xzoex
Re: Running to rich
« Reply #4 on: 08 July 2007, 23:02 »
Thanks hun will do  :smiley:
Offline KINGS>
Re: Running to rich
« Reply #5 on: 08 July 2007, 23:04 »
no worries... p.s when you have used the carb and choke cleaner (and do use plenty all round the carb throat and open the butterfly too) dont worry if the engine doesnt start first time and then throws loads of black sh!t out the zorst... thats a good sign!
Offline xzoex
Re: Running to rich
« Reply #6 on: 09 July 2007, 13:14 »
ill keep that in mind thanks for the heads up other wise i would have sh**t myself lol  :smiley:
Re: Running to rich
« Reply #7 on: 09 July 2007, 13:19 »
have a read thru my pierburg 2e2 FAQ before you fiddle with any of the carb settings, they are very sensitive and you should only adjust anyhting as a last resort.  There are many things that can go wrong on these things which cause rich running :)
Offline xzoex
Re: Running to rich
« Reply #8 on: 09 July 2007, 13:23 »
Whats that?? :huh:
Re: Running to rich
« Reply #9 on: 09 July 2007, 13:26 »
sorry the pierburg 2e2 is the type of carb fitted to 1.6 and 1.8 carb engined MK2s, it is possible you've had a webber fitted instead, do you have a choke cable? If not its a 2e2, if you do its probably a webber. Heres a link to my FAQ:
http://www.golfgtiforum.co.uk/index.php?topic=18871.0
