Author Topic: windscreen  (Read 2216 times)
Re: windscreen
« Reply #10 on: 09 July 2007, 13:03 »
its very hard to remove a screen in one piece without cutting the seal, if it was me I'd choose a cut seal over a cracked screen any day of the week!  Just nip to your local scrappy and nick a seal, no need to be gentle with a screen there, just boot it out :grin:
Offline xzoex
Re: windscreen
« Reply #11 on: 09 July 2007, 13:12 »
i think ill do that its not worth breaking the glass lol thanks :smiley:
Offline Mart8V
  • I really should know better by now.....
Re: windscreen
« Reply #12 on: 09 July 2007, 20:16 »
New seal cost me £27 from VAG- well worth it for knowledge that the bloody thing won't leak!
Windscreen cost me a pint....!!
Offline Mew
Re: windscreen
« Reply #13 on: 09 July 2007, 20:46 »
99p for my full set of green tint glass including windscreen with blue strip!  :wink:
That's not too bad for the seal actually. Like i said, i was lucky i was replacing my screen because it was cracked anyway, but if i ever do it again i'm definitely cutting the seal! No doubt about it.
Offline Thom89
  • Looking for an "Icebreaker"
Re: windscreen
« Reply #14 on: 10 July 2007, 00:29 »
If you break the seal between the body and the rubber, then the glass and the rubber with an old blunt screwdriver, you'll find that the screen will come out easily, just by feeding the inside rubber lip over the windscreen appeture, again, with old flat blade screwdrivers, takeing your time, is the key thing here, dont be tempted to push the screen at any stage, untill all you have left is the section above the dash, carefully push the screen forwards, then lift the screen out, job done
If you do manage to break the screen, the chances are that it would have broken anyway, on refitting!
Any stone chips that are close to the edge of the rubber are your weak points, so inspect carefully before you remove!
Using a 2nd hand screen rubber is not always a good idea! Firstly, if there are any splinters of glass left in the channel from the origional car, these can cause your newly fitted sceen to crack!  Secondly, screen rubbers can go out of shape! if they came off a car that has rust pushing through from under the rubber, fitted to your car, they could leak badly
Tom
Offline xzoex
Re: windscreen
« Reply #15 on: 10 July 2007, 10:53 »
Thanks tom ill try the blunt screwdriver as im on a very tight budget, well no budget really lol  :smiley:
Offline jammac
Re: windscreen
« Reply #16 on: 11 July 2007, 07:53 »
remember a stone flew up and hit your windscreen though when you break it with a screwdriver!!!  :sick:
ITS A TRAP!
Offline Thom89
Re: windscreen
« Reply #17 on: 12 July 2007, 00:47 »
^^  :wink: :wink: ^^
