Golf mk2
Rear door jammed shut!!!!
Topic: Rear door jammed shut!!!! (Read 1040 times)
dan7
85 T25 camper, 90 Mk2 16v, 90 Caddy
05 July 2007, 21:01 »
recently bought a 5 door 1987 golf 1.8 auto to get converted for my step dad, as he recently lost his leg in a work accident. Anyway, the rear driver's side door will not open from the inside or outside, just won't budge! How the fook can i get it open?! I can't get the interior panel off as there's four screws on the leading edge of the door! Any help would be greatly appreciated!
dubslug
Re: Rear door jammed shut!!!!
06 July 2007, 08:17 »
mine did this to me a few times, i had to wiggle the rear handle abt as much as i could and try it in all different places, it opened finally, i think i pushed the handle upwards as much as i could, hope this helps
1992 pearl grey 8v
dabill
06 July 2007, 12:06 »
why not look at local scarppers and find a replacement interior panel, then chop the old one out and do it like that, only be 5quid or so....
noble tuned - and still not fast enough!
Mr Blue
Forum addict
06 July 2007, 12:30 »
I had to cut the door handle
Done the job
dan7
06 July 2007, 16:54 »
Thanks for the help guys. I was considering cutting the interior panel, but it's an 86 GL and there ain't ANY in ANY breakers around here!!! May try cutting the handle then! Any more ideas greatly appreciated!
Dubbz
06 July 2007, 17:55 »
take the plastic or metal stirp off the handle,on the outside of car, there you'll find a screw phillips head quite short, play about with that, rock it about, up down.
Hopefully that'll flick the catch, you'll probabl find a little piec of metal has broken, it did on mine.
good luck.
2002 TDI se 100bhp-ish Auto/tip Black Magic.
Riki
Just got here
Reply #6 on:
06 July 2007, 20:51 »
Pull the door handle off the other side and have a look at the lock mechanism and how it operates. Then make up a slim jim to jemmy it open.
Riki
nealey
Reply #7 on:
06 July 2007, 20:58 »
had a similar problem with mine, a piece of metal had broken off the outer handle and jammed the mechanism up, i played about with the handle and it eventually opened
greasemonkey
Just got here
Reply #8 on:
06 July 2007, 23:10 »
try spraying wd40 into any gaps in around the handle and keep working the handle,mine then opened
Golf mk2
