Author Topic: No yellow wire !!!  (Read 3953 times)
Offline andydavey
Re: No yellow wire !!!
« Reply #10 on: 08 July 2007, 20:22 »
Yellow is actually permanent live (red is switched). Run a new one with decent gauge cable (about 12AWG should be fine) straight from the battery. Make sure you use an inline fuse near to the battery (can't remember how much current these units draw though, 15A should be about right, 10A would be better though if they don't draw more than that). Alpine actually recommend you do this anyway with their higher powered headunits if you plan to use the internal amps on them.
