Author Topic: Geometry setup with suspension change?  (Read 727 times)
Offline Classic16v
« on: 02 July 2007, 22:17 »
Just a quickie - if I change my front suspension will I have to redo all the geometry?  Only reason I ask is I just paid to have the camber re-set and would be bummed if i had to do it again after changing the suspension.  is it possible to do it myself if needs be, and do i need any specialist tools?
Offline Matt B
Re: Geometry setup with suspension change?
« Reply #1 on: 03 July 2007, 02:22 »
If by changing the front suspension you mean changing the shocks/springs then you'll probably need to get all the geometry setup again.  It is possible to do it by yourself but you'd need specialist tools that'd cost.
