Author Topic: I filled my g/box with water...I think  (Read 1019 times)
Offline Ben Lessani
« on: 02 July 2007, 21:25 »
I was flushing out the rad, as the water is constantly brown - stupid old cars. And in my ignorance I never realised that the cap covering the g/box (right next to the block on the top) wasn't on it, and that all the water from the hose filled it up.
The cap hasn't been on the g/box for a long time, so I'm thinking I should really flush it out.
Anyone have any thoughts on the level of problems im going to run into?
Ben
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
Re: I filled my g/box with water...I think
« Reply #1 on: 02 July 2007, 21:30 »
IF I WERE YOU I WOULD BUY A HAYNES MANUAL AS IT SOUNDS LIKE YOU DONT HAVE A CLUE. LOL
YOU HAVE FILL THE FLYWHEEL BALL HOUSING. DONT WORRY. TAKE YOUR CAR FOR A SPIN AND BY THE TIME YOU GET BACK IT WILL HAVE GONE. THE HOLE IS USUALLY COVERED WITH A GREEN CAP BUT ALOT OF MECHANICS NEVER BOTHER TO PUT THEN BACK.
YOU ARE SAFE BROTHER.   :grin:
Offline Ben Lessani
« Reply #2 on: 02 July 2007, 22:09 »
I thought it might be the flywheel housing, but I wasn't 100%, hence why I did a little post on here. Thanks for the help, let me offer some.. the CAPS LOCK button can be pressed to make internet communication easier!
Offline dubslug
« Reply #3 on: 03 July 2007, 17:07 »
lol at both of u
1992 pearl grey 8v
Offline tom26
  • team chumpy.
« Reply #4 on: 03 July 2007, 17:35 »
^^ :laugh:
Offline yorkie
« Reply #5 on: 04 July 2007, 19:06 »
As already said the hole in the top of the bell housing is to check the timing and should have a Green rubber plug in it.
I doubt if you have done too much harm as there is a hole in the bottom to allow oil to drain out if the crank oil seal leaks.
The water will have drained out so a quick spin to heat everything up should dry the rest out nicely.
