Author Topic: 8 valve not starting  (Read 3381 times)
Offline raj
« on: 16 February 2004, 17:42 »
hi guys, i have just had my head reconditioned. and have put it back together. but my car is not starting. i have the timing on TDC, there is sparks comminig from the plugs, all the wires are connected. can any body help please?
golfvr6
Re:8 valve not starting
« Reply #1 on: 16 February 2004, 17:48 »
Remove the centre lead from the distributor, is there a spark from the coil?
Offline raj
« Reply #2 on: 16 February 2004, 18:22 »
yeah the coil is sparking.
i have just noticed that a black wire which is hanging. it comes along with the wires that go the idle stabliser valve and the ones that go to the injection rail. any ideas where that goes?
golfvr6
« Reply #3 on: 16 February 2004, 18:30 »
Can you put a pic on the gallery?
Have you removed the distributor?
If you have then make sure it is engaged in the slot.
Offline raj
« Reply #4 on: 16 February 2004, 18:35 »
sorry i cant put picture up. i havent taken the distributor out but have taken the cap off.
Blue MK2
« Reply #5 on: 16 February 2004, 19:21 »
if you need a distributor then i have a spare for sale Raj
Digifant engine i take it?
Offline raj
« Reply #6 on: 17 February 2004, 20:36 »
cheers mate but i dont think its the distribuor because its sparking the plugs.
golfvr6
« Reply #7 on: 17 February 2004, 20:38 »
Is the ignition timing correct?
Try cranking the engine while a mate turns the dizzy back and foward.
Offline mk1
« Reply #8 on: 17 February 2004, 20:40 »
Did you plug the injector connection in?.
Steve.
golfvr6
« Reply #9 on: 17 February 2004, 20:50 »
Good shooting Steve  ;)
Could that be the connector thats not plugged in?
