Author Topic: i want to de-coke me engine - which pipe do i put into water??  (Read 1124 times)
Offline BobbyT
not sure what pipe i need to put into water to do this trick? on a 1.8 dx lump! cheers, rob
Offline ...joe
:huh: water? don't know this trick?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline BobbyT
well i read i here a while back that if you disconect one of the vac pipes and suck up a pint of water it will clear all carbon de-posit's from the engine (like a internal steam clean!) just fancied giving it a go!  :undecided:  :smiley:
Offline cняis
i can verify that it works... reduced my pinking issue no end  :smiley:
might give it another go sometime.
i think the trick is to use a small diameter vac pipe that goes straight into the head? i have the PB engine and used the pipe which goes from the airbox to the head.
