Author Topic: Alignment settings  (Read 667 times)
Offline rowlers
  • I'm back - MK7 GTI
Alignment settings
« on: 28 June 2007, 17:11 »
Going to be setting everything up in terms of toe and camber on sat morning, so that I don't scrub my shiny new tyres!
Anyone know the correct settings I need to be going for, bearing in mind its lowered on 20mm eibachs.
Also - both track rods will have been adjusted at some point (This is WRONG I believe, only pass side should be adjusted?) How do I put everything back to where is should be - is there any measurments for the trackrods?
Cheers all
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
Re: Alignment settings
« Reply #1 on: 28 June 2007, 21:12 »
you are entering a whole world of myther. i wouldnt mess if your having new tyres. take it somewhere to get it done. kwik fit did mine, it only cost me 30 quid for track and camber. its state of the art too
Offline rowlers
« Reply #2 on: 28 June 2007, 21:40 »
I'll be using the proper gear - at my mates garage :wink:
If I do it myself, then I know its right :smiley:
Last tyre place done and I have no rubber left on the insides, so I want it right!
