Author Topic: mk 16v g reg  (Read 1085 times)
Offline beetle_boy
mk 16v g reg
« on: 24 June 2007, 20:44 »
hi i got a mk2 16v and the belt broke. so the heads off now and i was wondering what i could do to it while its off. as in biger vales gasflow head eny ideas would be very cool thanks
Offline monkeyalan
Re: mk 16v g reg
« Reply #1 on: 25 June 2007, 09:55 »
depends how much you want to spend and what your skill levels are.
The easiest thing to do is just de-coke everything with emery paper so it's all nice and clean and re-seat the valves.
You could match the inlet and exhaust manifold ports to their respective manifolds with too much risk of
f-ing things up if it's the first time you done anything like this.
After that there's porting, but it's quite a risky job for a first timer as it's easy to make performance and fuel use worse if you do it wrong.
« Last Edit: 25 June 2007, 09:58 by monkeyalan »
Offline beetle_boy
Re: mk 16v g reg
« Reply #2 on: 26 June 2007, 20:36 »
hi ye i am a mecanic i know all bout gasfow heads and bigger valves and polish ports and stuff i just wanted 2 know wats best 4 the valver heads iv already de coked it it was full of carbon and might c bout openin up the inlet ports 2 nice 1 thanks big help. eny info on hight lift cams .G.
